CNC tools, perfect for prototyping, light industrial, and hobbyist use
Our delivery and customer support services are available to customers across the UK
Receive a personalised guide to learn about your milling machine and PathPilot software
Our finance partners provide you with a solution to get you closer to cutting chips
Hear from hobbyist and commercial makers throughout the Tormaker Community
Compact and versatile, the 1100M gets the job done - even in tight spaces
It cuts through aluminium, plastics, wood, steel and even titanium with ease
The 1100M uses PathPilot® control software developed by Tormach, and its intuitive interface lets you follow your instincts
The Tormach 1100M is indispensable for prototyping, light production, education, and hobbyist applications
The 1100MX is a compact CNC mill with more punching power
It fits almost anywhere, and cuts almost anything - aluminium, plastics, wood, steel and even titanium
The 1100MX is the newest generation of CNC that offers value, performance, and support
We gave our 1100MX a trio of servo motors, an encoder for rigid tapping, and a BT30 spindle
Faster travel speeds cut down program times, and a beefier spindle chews through aluminum, titanium, hardened steels, and alloys without concern of tool pullout
The 770M is a little workhorse and runs on single-phase power
Its flexible and can rise to the challenge, with unrivalled performance and capability in its class
Multiple work setups combined with an automatic tool changer allow it to be used as a short-run production machine
Plus, it plays well with all popular CAD/CAM softwares, speeding up time to market
The Tormach 770M is built to machine all types of materials - from softer materials like aluminum, wood or plastics, to tougher materials such as titanium
The 770MX is full of details that make using it a pleasure
It fits almost anywhere and cuts almost anything - the 700MX is a compact CNC mill with more punching power
We gave our 770MX a trio of servo motors, an encoder for rigid tapping, and a BT30 spindle
Plus, the premium features aren’t hidden behind a paywall that’ll run you thousands of pounds. If it’s in PathPilot, you have access
The PCNC 440 is the little engine that can
It’s a benchtop mill that fits all-around capability in a small and affordable package, the PCNC 440 makes it possible for more spaces to become machine shops
It can cut aluminum, steel, titanium, as well as plastics, composites, wood, and PCB boards - anything our other mills can cut
It’s controlled by PathPilot® which easily interfaces with most popular CAD/CAM systems
The PCNC 440 features a Cast Iron Frame and Table, Dovetail Ways, Ball Screws, 10,000 RPM R8 Spindle and 10” x 6.25” x 10” Work Envelope
The xsTECH Router is a desktop CNC ready to use out of the box
It's small enough to fit in a craftroom or makerspace, and it's capable enough to cut all manners of plastics, woods and even aluminium
The see-through enclosure offers safe use and controls dust that can muck up your space and electronics
The xsTECH Router uses our award-winner PathPilot®️ control software
It's the only table top router with PathPilot®️, and that'll get your from un-crating to using in less time
They have the capabilities that other small machines envy.
Smart machines for light industry and prototypes
© Copyright 2021 Tormach Inc. All Rights Reserved
Privacy & Cookie Policy
Cookie Settings
Terms & Conditions
Support Policy
